주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ZenPad S 8.0 Battery Replacement
필요한 것
    1. ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 3개
      • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
      • Use the plastic tool to pry between the silver bezel and the back case
      • Work the tool around the device to free the back case
      댓글 쓰기
    2. ASUS ZenPad S 8.0 Battery Replacement: 2 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
      • Do not kink the ribbon cables as they can break easily
      댓글 쓰기
    3. ASUS ZenPad S 8.0 Battery Replacement: 3 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Battery Replacement: 3 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
      댓글 쓰기
    4. ASUS ZenPad S 8.0 Battery Replacement: 4 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Remove all 9 of the 1.5mm #00 Philips screws
      • Gently lift the battery out of the device
      • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Ensure that the MicroSD card slot cover is in its closed position before re-attaching the rear cover.
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Samantha Brown
회원 가입일: 10/04/16
164 평판
안내서 1개를 작성함
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G2
4 회원들
안내서 5개를 작성함
20가이드 댓글
Thanks for this tutorial. Any chance anybody knows the part number for the battery and a good source?
danpobrien - 답글 공유
Yes, A good tutorial but part number for the battery would be useful
celdor - 답글 공유
Doh! its in the pictures its a C11Pn9H should have spotted that.
celdor - 답글 공유
The original battery says” Rating 3.8v 15.2 Wh” and “Capacity 4000mAh(TYP) 3984mAh(MIN)”
Clone batteries may be lower. Wish I’d bought a “factory battery”
license - 답글 공유
Tutorial was perfect, much easier than I thought. Unfortunately swapping the battery did not fix my tablet, but I feel a lot more confident now to try fixing things like this first instead of just automatically throwing them away. Thanks!
cdclemons - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 70
전체 시간: 26,213
