주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ZenPad S 8.0 Front Facing Camera Replacement
필요한 것
    1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 3개
      • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
      • Use the plastic tool to pry between the silver bezel and the back case
      • Work the tool around the device to free the back case
      댓글 쓰기
    2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
      • Do not kink the ribbon cables as they can break easily
      댓글 쓰기
    3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
      댓글 쓰기
    4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Remove all 9 of the 1.5mm #00 Philips screws
      • Gently lift the battery out of the device
      • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
      댓글 쓰기
    1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
      댓글 쓰기
    2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a tweezers to lift out the camera
      • If you lifted the latch for the ribbon cable then it should come out with little resistance.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
John Astfanous
회원 가입일: 10/04/16
987 평판
안내서 3개를 작성함
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 1,655
