주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ZenWatch Vibration motor Replacement
필요한 것
    1. ASUS ZenWatch Vibration motor Replacement, Watch Strap Removal: 1 단계, 이미지 2개 중 1개 ASUS ZenWatch Vibration motor Replacement, Watch Strap Removal: 1 단계, 이미지 2개 중 2개
      • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
      댓글 쓰기
    1. ASUS ZenWatch Vibration motor Replacement, Battery: 2 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement, Battery: 2 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement, Battery: 2 단계, 이미지 3개 중 3개
      • Use the T5 Torx driver to remove the four screws on the case.
      • Use the magnetic pad to keep all your parts easily contained!
      • The case will pry easily off with just gentle hand pressure
      댓글 쓰기
    2. ASUS ZenWatch Vibration motor Replacement: 3 단계, 이미지 2개 중 1개 ASUS ZenWatch Vibration motor Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using the tweezers, gently remove the fabric protecting the battery connection.
      • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
      • Use the heavy duty spudger to gently push the contact towards the top of the case.
      댓글 쓰기
    3. ASUS ZenWatch Vibration motor Replacement: 4 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement: 4 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement: 4 단계, 이미지 3개 중 3개
      • Gently pry the battery up with the plastic pry tools
      댓글 쓰기
    1. ASUS ZenWatch Vibration motor Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the metal tweezers gently remove the fabric covering the connection on bottom right
      • Using the heavy duty plastic spudger pry up on the connection ribbon.
      • There are two connection ports on the single ribbon. Do not use too much force as you may tear ribbon!
      댓글 쓰기
    2. ASUS ZenWatch Vibration motor Replacement: 6 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement: 6 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Heavy-Duty Spudger
      • The protective plate is now ready to be safely removed.
      • With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
      • There are tiny notches on plate making it simple to pull up on each side.
      • A small strip of adhesive is on back of plate as well.
      • Remove loosened plate and set aside.
      댓글 쓰기
    3. ASUS ZenWatch Vibration motor Replacement: 7 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement: 7 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement: 7 단계, 이미지 3개 중 3개
      • With the 000 Philips screwdriver remove the screw and plastic retainer clips
      댓글 쓰기
    4. ASUS ZenWatch Vibration motor Replacement: 8 단계, 이미지 2개 중 1개 ASUS ZenWatch Vibration motor Replacement: 8 단계, 이미지 2개 중 2개
      • With heavy duty spudger lift up on final connection ribbon located on left corner.
      댓글 쓰기
    5. ASUS ZenWatch Vibration motor Replacement: 9 단계, 이미지 2개 중 1개 ASUS ZenWatch Vibration motor Replacement: 9 단계, 이미지 2개 중 2개
      • With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
      댓글 쓰기
    1. ASUS ZenWatch Vibration motor Replacement, Vibration motor: 10 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement, Vibration motor: 10 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement, Vibration motor: 10 단계, 이미지 3개 중 3개
      • With a flat metal spudger pry back the little metal clamps that hold the motor secure.
      • Do not bend these too far as they can easily break off!
      댓글 쓰기
    2. ASUS ZenWatch Vibration motor Replacement: 11 단계, 이미지 3개 중 1개 ASUS ZenWatch Vibration motor Replacement: 11 단계, 이미지 3개 중 2개 ASUS ZenWatch Vibration motor Replacement: 11 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the soldering iron, heat the two solder tabs on back of motor.
      • Use metal tweezers to pull up and remove motor.
      • A soldering iron gets hot! Take care not to burn yourself or place it on any other part of the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Wayne McClure
회원 가입일: 02/10/16
961 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 24
전체 시간: 1,175
