주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AT-LP60X Setup Guide
  1. AT-LP60X Setup Guide, Place Turntable: 1 단계, 이미지 2개 중 1개 AT-LP60X Setup Guide, Place Turntable: 1 단계, 이미지 2개 중 2개
    • Place your turntable on a clear, flat surface.
    • Ensure there is no power connected to the turntable at this time.
    댓글 쓰기
  2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: 2 단계, 이미지 1개 중 1개
    • Obtain the silver metal platter.
    • Verify that the belt is installed around the inner ring of the platter.
    댓글 쓰기
  3. AT-LP60X Setup Guide, Install Platter: 3 단계, 이미지 2개 중 1개 AT-LP60X Setup Guide, Install Platter: 3 단계, 이미지 2개 중 2개
    • Place the platter on the center spindle.
    • Rotate the platter to show the gold pulley of the motor.
    • Stretch the belt from the platter over the gold pulley of the motor.
    댓글 쓰기
  4. AT-LP60X Setup Guide, Preform Mechanical Reset: 4 단계, 이미지 2개 중 1개 AT-LP60X Setup Guide, Preform Mechanical Reset: 4 단계, 이미지 2개 중 2개
    • Place the slipmat on top of the platter and press the STOP button.
    • With your right hand, hold the tone arm in place.
    • [OPTIONAL] use the included hook and twist tie for this step.
    • With your left hand, rotate the platter clockwise about 10 times.
    • You should hear a series of clicks and pops.
    댓글 쓰기
  5. AT-LP60X Setup Guide, Reconnect Turntable: 5 단계, 이미지 1개 중 1개
    • Reconnect the power supply.
    • Connect the 3.5mm to RCA to your speakers.
    • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
    • The output switch position does not matter if you are connecting to a Bluetooth speaker.
    댓글 쓰기
  6. AT-LP60X Setup Guide, Prepare Tonearm: 6 단계, 이미지 3개 중 1개 AT-LP60X Setup Guide, Prepare Tonearm: 6 단계, 이미지 3개 중 2개 AT-LP60X Setup Guide, Prepare Tonearm: 6 단계, 이미지 3개 중 3개
    • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
    • Unsecure the twist tie from the built-in hook (if present).
    • Ensure the tone arm lift button is in the outward position.
    • The setup is now complete and you are ready to try a record!
    댓글 쓰기
결론
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony @ ATUS
회원 가입일: 02/28/19
1,195 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 30
지난 30일: 100
전체 시간: 1,156
