주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ATT EL52300 Keypad/Plastic Display Screen Replacement
필요한 것
  1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
    댓글 쓰기
  2. ATT EL52300 Keypad/Plastic Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
    댓글 쓰기
  3. ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
    댓글 쓰기
  4. ATT EL52300 Keypad/Plastic Display Screen Replacement: 4 단계, 이미지 2개 중 1개 ATT EL52300 Keypad/Plastic Display Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
    댓글 쓰기
  5. ATT EL52300 Keypad/Plastic Display Screen Replacement: 5 단계, 이미지 2개 중 1개 ATT EL52300 Keypad/Plastic Display Screen Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
    댓글 쓰기
  6. ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: 6 단계, 이미지 2개 중 1개 ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: 6 단계, 이미지 2개 중 2개
    • The keypad lies on the top of the motherboard and is easily detachable.
    • Remove the keypad.
    댓글 쓰기
  7. ATT EL52300 Keypad/Plastic Display Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Replace the plastic display screen, or the keypad buttons as needed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Katty
회원 가입일: 08/27/15
340 평판
안내서 3개를 작성함
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G1
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 775
