주요 콘텐츠로 건너뛰기
Abask J05 Screen Replacement
필요한 것
  1. Abask J05 Screen Replacement, Front Case: 1 단계, 이미지 1/2 Abask J05 Screen Replacement, Front Case: 1 단계, 이미지 2/2
    • Gently press on the SD card with a fingernail until it clicks.
    • Release, then remove the card.
  2. Abask J05 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the 5 mm screw from the side of the device next to the suction cup dock with a Phillips #00 screwdriver.
  3. Abask J05 Screen Replacement: 3 단계, 이미지 1/2 Abask J05 Screen Replacement: 3 단계, 이미지 2/2
    • Remove the two 8 mm screws from opposite sides of the screen with a Phillips #00 precision screwdriver.
  4. Abask J05 Screen Replacement: 4 단계, 이미지 1/2 Abask J05 Screen Replacement: 4 단계, 이미지 2/2
    • Gently lift the screen.
    • Push up on the interior camera portion of the device. It should pop out of the socket. Being careful to keep the wires attached, set it to the side.
  5. Abask J05 Screen Replacement: 5 단계, 이미지 1/2 Abask J05 Screen Replacement: 5 단계, 이미지 2/2
    • Reach into the device with a spudger to release the top two snap joints keeping the end cap attached one at a time until the front face lifts off.
    • Be careful not to touch the screen.
    • Repeat the process with the two remaining snap joints.
  6. Abask J05 Screen Replacement, Screen: 6 단계, 이미지 1/2 Abask J05 Screen Replacement, Screen: 6 단계, 이미지 2/2
    • Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
    • Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
    • Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
  7. Abask J05 Screen Replacement: 7 단계, 이미지 1/3 Abask J05 Screen Replacement: 7 단계, 이미지 2/3 Abask J05 Screen Replacement: 7 단계, 이미지 3/3
    • Carefully flip over the motherboard, being mindful of the wires.
    • Remove the two 5mm screws on the underside of the motherboard with a Phillips #000 screwdriver.
  8. Abask J05 Screen Replacement: 8 단계, 이미지 1/2 Abask J05 Screen Replacement: 8 단계, 이미지 2/2
    • Follow the golden ribbon from the screen to the screen dock. Push the two small black stubs on either side of the dock away from the dock until it pops loose.
    • Remove the ribbon and the small plastic piece from the dock.
  9. Abask J05 Screen Replacement: 9 단계, 이미지 1/2 Abask J05 Screen Replacement: 9 단계, 이미지 2/2
    • Gently pull up on each corner of the white screen piece until the adhesive comes loose.
    • Remove the screen fully from its holder.
결론
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
다른 2명이 해당 안내서를 완성하였습니다.
Valerie Kulnar
회원 가입일: 09/12/23
680 평판
안내서 5개 작성하였습니다
University of North Texas, Team 2-2, Harold Fall 2023 University of North Texas, Team 2-2, Harold Fall 2023 회원
UNT-HAROLD-F23S2G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 86
