주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer AL1916 Motherboard Replacement
필요한 것
    1. Acer AL1916 Motherboard Replacement, Stand: 1 단계, 이미지 1개 중 1개
      • Lay the monitor on a flat surface so that the back is facing up.
      댓글 쓰기
    2. Acer AL1916 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Grab the hinge cover with both hands on either side of the stand.
      • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
      댓글 쓰기
    3. Acer AL1916 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
      • Support the monitor while removing the screws to prevent the monitor from falling.
      • Lift up to detach the stand.
      댓글 쓰기
    1. Acer AL1916 Motherboard Replacement, Outer Case: 4 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement, Outer Case: 4 단계, 이미지 2개 중 2개
      • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
      댓글 쓰기
    2. Acer AL1916 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Acer AL1916 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Acer AL1916 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
      • Tilt the plastic opening tool up to separate the back cover from the display bezel.
      • Continue around the perimeter of the monitor until the display bezel comes off.
      • A reasonable amount of force is necessary to detach the back cover from the display bezel.
      댓글 쓰기
    3. Acer AL1916 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Reposition the monitor so that the back is facing up.
      • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
      • Lift the back cover up.
      댓글 쓰기
    1. Acer AL1916 Motherboard Replacement, EMI Shield: 7 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement, EMI Shield: 7 단계, 이미지 2개 중 2개
      • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
      댓글 쓰기
    2. Acer AL1916 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
      댓글 쓰기
    3. Acer AL1916 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Acer AL1916 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Acer AL1916 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
      • Lift up to remove the metal casing.
      • Beware, metal casing is sharp!
      댓글 쓰기
    1. Acer AL1916 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
      • Remove the beige control cable to the left of the VGA input by pulling it up.
      댓글 쓰기
    2. Acer AL1916 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the rainbow-colored power cable by pulling it straight up.
      댓글 쓰기
    3. Acer AL1916 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Acer AL1916 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the display cable located at the top of the motherboard by pulling it out towards the top of the monitor.
      댓글 쓰기
    4. Acer AL1916 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Acer AL1916 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Acer AL1916 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
      • Remove the three 7.7 mm Phillips #2 screws from the motherboard, and take out the motherboard by lifting it up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Taylor Atterbury
회원 가입일: 10/06/11
747 평판
안내서 3개를 작성함
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 회원
CPSU-MANESS-F11S20G26
4 회원들
안내서 14개를 작성함
3가이드 댓글
How does one know weather it's the Motherboard or the PSU? What should the PSU be outputting to check it first? Or any other ways to check it
Tyler Wight - 답글 공유
there are a few things that can help diagnose whether it is the power supply or the circuit board but sometimes it can be both. One thing you can do is just knowing the conditions of the home, did you have some power outage, or blinking of lights during storms and things like that. If you don't have a battery backup sometimes surge protectors are not going to save a system from failure just from power blinking on and off. This can cause backfire like issues that can glitch out the control board or power supply or domino the both. If you see power and the light turns on but when you hit the buttons nothing happens that either means the circuit board is failed because it is unable to process commands, or the power supply is only providing enough power to turn on the circuit board but nothing else. If you can not get a light at all and have tried plugging it in and out over and over and nothing no lights or anything than it is a good bet the power board has failed. If you don'twant to pay repairs take best guess
jamhi - 답글 공유
Very often, espacially if the PSU is som years old, the electrolyt capacitors will dry out.
You can see it when the surface has blown up and is rounded. Normally this capacitors are flat. If you see, that one or more of this capacitors is bended, than replace all with the same values (capacity and voltage).
Eugen Schöller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 45
전체 시간: 8,740
