주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 3000 RAM Replacement
필요한 것
  1. Acer Aspire 3000 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
    댓글 쓰기
  2. Acer Aspire 3000 RAM Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3000 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
    댓글 쓰기
  3. Acer Aspire 3000 RAM Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3000 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
    댓글 쓰기
  4. Acer Aspire 3000 RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
    댓글 쓰기
  5. Acer Aspire 3000 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
    댓글 쓰기
  6. Acer Aspire 3000 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
    댓글 쓰기
  7. Acer Aspire 3000 RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Lift and pull the cover back towards you to detach it from the device.
    댓글 쓰기
  8. Acer Aspire 3000 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
    댓글 쓰기
  9. Acer Aspire 3000 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Pull and lift the chip to release it from the RAM port.
    댓글 쓰기
  10. Acer Aspire 3000 RAM Replacement: 10 단계, 이미지 1개 중 1개
    • Repeat step 9 to release the bottom chip from its RAM port.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
roro6730
회원 가입일: 10/30/16
351 평판
안내서 2개를 작성함
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 28
전체 시간: 1,080
