주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 5253 RAM Replacement
필요한 것
  1. Acer Aspire 5253 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over.
    댓글 쓰기
  2. Acer Aspire 5253 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    댓글 쓰기
  3. Acer Aspire 5253 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    댓글 쓰기
  4. Acer Aspire 5253 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    댓글 쓰기
  5. Acer Aspire 5253 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • You have successfully removed the battery. Congratulations!
    댓글 쓰기
  6. Acer Aspire 5253 RAM Replacement, Back Cover Panel: 6 단계, 이미지 1개 중 1개
    • Now, locate the two screws that hold the back cover panel onto the laptop.
    댓글 쓰기
  7. Acer Aspire 5253 RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
    댓글 쓰기
  8. Acer Aspire 5253 RAM Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire 5253 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
    댓글 쓰기
  9. Acer Aspire 5253 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
    댓글 쓰기
  10. Acer Aspire 5253 RAM Replacement, RAM: 10 단계, 이미지 1개 중 1개
    • Now, locate the RAM.
    댓글 쓰기
  11. Acer Aspire 5253 RAM Replacement: 11 단계, 이미지 1개 중 1개
    • Locate the two metal pieces on both sides of the RAM that are holding it in place.
    댓글 쓰기
  12. Acer Aspire 5253 RAM Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the tabs apart to remove the RAM.
    • The RAM will pop up once they are pried open.
    댓글 쓰기
  13. Acer Aspire 5253 RAM Replacement: 13 단계, 이미지 2개 중 1개 Acer Aspire 5253 RAM Replacement: 13 단계, 이미지 2개 중 2개
    • Carefully slide the RAM out of the compartment.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cynthia Barajas
회원 가입일: 04/08/14
2,258 평판
안내서 5개를 작성함
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014 회원
CPSU-REGAN-S14S8G11
4 회원들
안내서 15개를 작성함
1가이드 댓글
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 51
전체 시간: 4,492
