주요 콘텐츠로 건너뛰기
Acer E5-571-54FL Battery Replacement
필요한 것
  1. Acer E5-571-54FL Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Battery Replacement: 2 단계, 이미지 1/2 Acer E5-571-54FL Battery Replacement: 2 단계, 이미지 2/2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Battery Replacement: 3 단계, 이미지 1/2 Acer E5-571-54FL Battery Replacement: 3 단계, 이미지 2/2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aaron Weissman
회원 가입일: 10/23/17
1,004 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 UMass Dartmouth, Team S3-G8, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G8
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 50
전체 시간: 2,644
