주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Iconia Tab A500 Screen Replacement
필요한 것
    1. Acer Iconia Tab A500 Screen Replacement, Back Case: 1 단계, 이미지 1개 중 1개
      • To start, gently separate one corner of the case using the black spudger.
      댓글 쓰기
    2. Acer Iconia Tab A500 Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
      댓글 쓰기
    1. Acer Iconia Tab A500 Screen Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Remove the 5mm screws that are securing the battery to the rest of the tablet.
      • Use the Phillips #00 Screwdriver to remove the 5mm screws.
      댓글 쓰기
    2. Acer Iconia Tab A500 Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Use the sharper end of the spudger to disconnect the battery from the mother board.
      • The battery connector will slide off.
      댓글 쓰기
    1. Acer Iconia Tab A500 Screen Replacement, Speakers: 5 단계, 이미지 1개 중 1개
      • Locate the 4 screws and cable that hold in the two speakers.
      • Use the Phillips #1 screwdriver to remove these 2mm black screws.
      • Remove the 2mm silver screws.
      • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
      댓글 쓰기
    2. Acer Iconia Tab A500 Screen Replacement: 6 단계, 이미지 2개 중 1개 Acer Iconia Tab A500 Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Carefully remove the connector cable by pushing on the rim of black plastic insert.
      댓글 쓰기
    3. Acer Iconia Tab A500 Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Unfortunately, the top speaker is a wedged under the motherboard.
      • To get this speaker out, use the spudger and gently pry it out.
      댓글 쓰기
    1. Acer Iconia Tab A500 Screen Replacement, Power Button: 8 단계, 이미지 1개 중 1개
      • Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
      • They may be different sizes, the silver are 5mm and the black are 2mm.
      댓글 쓰기
    2. Acer Iconia Tab A500 Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Lift up on the black flaps to release the flat cables.
      • Pull this Connector off.
      댓글 쓰기
    3. Acer Iconia Tab A500 Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Use the spudger to detach the indicated cables.
      • Remove the last motherboard screw under the rightmost cable. It is a silver 5mm.
      댓글 쓰기
    4. Acer Iconia Tab A500 Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Disconnect the two gold connectors by pulling straight up on them with your fingers.
      • Like before, lift up on the black flap to detach the cable.
      댓글 쓰기
    5. Acer Iconia Tab A500 Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Having disconnected all those pesky cables, the motherboard lifts cleanly out.
      댓글 쓰기
    1. Acer Iconia Tab A500 Screen Replacement, Screen: 13 단계, 이미지 1개 중 1개
      • Remove this components near the edge of the tablet by unscrewing the 5mm screw holding the top in place.
      댓글 쓰기
    2. Acer Iconia Tab A500 Screen Replacement: 14 단계, 이미지 1개 중 1개
      • Lift the silver case, exposing the back side of the screen.
      댓글 쓰기
    3. Acer Iconia Tab A500 Screen Replacement: 15 단계, 이미지 1개 중 1개
      • Use the spudger to pry off the screen, it is held in by a film of glue around the rim.
      댓글 쓰기
    4. Acer Iconia Tab A500 Screen Replacement: 16 단계, 이미지 1개 중 1개
      • Swap the screen and you're finished!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kyle Libby
회원 가입일: 04/07/14
1,006 평판
안내서 7개를 작성함
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 회원
CPSU-REGAN-S14S7G23
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 32
전체 시간: 13,547
