주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Adding ADXL345 Accelerometer
필요한 것
    1. Adding ADXL345 Accelerometer, Wiring: 1 단계, 이미지 1개 중 1개
      • Connect the Accelerometer to the RPI
      • Accelerometer 3V3 to RPI pin 17 3.3v
      • Accelerometer GND to RPI pin 20 Ground
      • Accelerometer CS to RPI pin 24 GPIO08 (SPI0_CE0_N)
      • Accelerometer SDO 21 to RPI pin GPIO09 (SPI0_MISO)
      • Accelerometer SDA to RPI pin 19 GPIO10 (SPI0_MOSI)
      • Accelerometer SCL 23 to RPI pin GPIO11 (SPI0_SCLK)
      댓글 쓰기
    2. Adding ADXL345 Accelerometer, Mounting the ADXL345: 2 단계, 이미지 1개 중 1개
      • There are a number of options you can use to mount the accelerometer. I used this mount
      댓글 쓰기
    3. Adding ADXL345 Accelerometer, Installing The Packages: 3 단계, 이미지 1개 중 1개
      • You need to SSH into to your printer and install Numby.
      • ~/klippy-env/bin/pip install -v numpy
      • Be patient, this package can take 10-20 minutes to install. When finished run:
      • sudo apt update
      • sudo apt install python3-numpy python3-matplotlib -y
      • Verify Linux SPI driver is enabled
      • sudo raspi-config
      • #3 Interface Options > P4 SPI > Yes > OK > Finish
      댓글 쓰기
    4. Adding ADXL345 Accelerometer, Preparing printer.cfg: 4 단계, 이미지 1개 중 1개
      • Uncomment the input shaper & resonance tester section in the config.
      • probe_points: It's recommended to use 1 point in the center of the bed slightly above. I used the same coordinates used when homing Z
      • Restart klipper with
      • RESTART
      댓글 쓰기
    5. Adding ADXL345 Accelerometer, Prechecks: 5 단계, 이미지 1개 중 1개
      • Check to make sure the RPI can communicate with the ADXL345 by running the following command in console
      • ACCELEROMETER_QUERY
      • It should return something like:
      • adxl345 values (x, y, z): -152.983740, 10249.910580, 152.983740
      • f you get an error like Invalid adxl345 id (got xx vs e5), where xx is some other ID, it is indicative of the connection problem with ADXL345, or the faulty sensor. Double-check the power, the wiring (that it matches the schematics, no wire is broken or loose, etc.), and soldering quality.
      댓글 쓰기
      • Home the printer.
      • During resonance testing the vibrations can become extremely violent. Make sure you're in proximity of the printer in case you need to cancel the test with M112
      • Now you can run the first resonance test for X
      • TEST_RESONANCES AXIS=X
      • When the test completes run it again for Y
      • TEST_RESONANCES AXIS=Y
      • When the test is complete it will generate CSV files stored on the pi.
      댓글 쓰기
    6. Adding ADXL345 Accelerometer, Interpreting Resonance Results: 7 단계, 이미지 2개 중 1개 Adding ADXL345 Accelerometer, Interpreting Resonance Results: 7 단계, 이미지 2개 중 2개
      • SSH back in to the printer and run the following 2 commands
      • ~/klipper/scripts/calibrate_shaper.py /tmp/resonances_x_*.csv -o /tmp/shaper_calibrate_x.png
      • ~/klipper/scripts/calibrate_shaper.py /tmp/resonances_y_*.csv -o /tmp/shaper_calibrate_y.png
      • This script will generate the charts /tmp/shaper_calibrate_x.png and /tmp/shaper_calibrate_y.png with frequency responses
      • You can use WINSCP to copy them to your PC if you like but it's not necessary.
      • You will also get the suggested frequencies for each input shaper, as well as which input shaper is recommended for your setup.
      • You can see my values for X
      • You can see my values for Y
      댓글 쓰기
    7. Adding ADXL345 Accelerometer, Comparing Belt Tension: 8 단계, 이미지 2개 중 1개 Adding ADXL345 Accelerometer, Comparing Belt Tension: 8 단계, 이미지 2개 중 2개
      • With a CoreXY you can also use Klipper to compare belt tension between X and Y. This doesn't tell you if the belts are too tight or too loose. It tells you have the belts are tensioned equally.
      • Run the following commands in the console
      • TEST_RESONANCES AXIS=1,1 OUTPUT=raw_data
      • TEST_RESONANCES AXIS=1,-1 OUTPUT=raw_data
      • SSH into the pi and run
      • ~/klipper/scripts/graph_accelerometer.py -c /tmp/raw_data_axis*.csv -o /tmp/resonances.png
      • Based off the generated graph, X had much higher frequencies than Y. I had to tighten the left belt tensioner to to bring the frequencies closer to each other.
      • As you can see from the 2nd test the frequencies for X and Y are closer together, but could still use a little more adjustment. I think a lot of the frequency variation is due to my cable chain. At lower frequencies it rattles considerably more only when calibrating X.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,382 평판
안내서 33개를 작성함
1가이드 댓글
Great Post! You might want to add a paragraph on the RPi Microcontroller for multi mcu with the pi
gary - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 102
전체 시간: 35,100
