주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Air Blasters Tek Six Reload Slider Spring Replacement
필요한 것
    1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 3개 중 1개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 3개 중 2개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 3개 중 3개
      • Using a Phillips #00 screwdriver, remove the two 11.6 mm screws that hold the grey slider together
      • Remove grey slider from the main body of the blaster.
      댓글 쓰기
    2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 3개 중 1개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 3개 중 2개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 3개 중 3개
      • Using a Phillips #00 screwdriver, remove the six 9 mm screws that secure the main body.
      댓글 쓰기
    3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 3개 중 1개 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 3개 중 2개 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 3개 중 3개
      • Using the plastic opening tools, carefully separate the main case of the blaster to expose the inside.
      댓글 쓰기
    4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 3개 중 1개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 3개 중 2개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 3개 중 3개
      • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
      댓글 쓰기
    5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 5 단계, 이미지 2개 중 1개 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 5 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the 7.5 mm Phillips #00 screw holding the top spring to the reload slider.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Alfredo Antolinez
회원 가입일: 09/22/14
347 평판
안내서 3개를 작성함
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 회원
USFT-BROWN-F14S3G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 43
전체 시간: 875
