주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AirCard 770S SIM Card Replacement
  1. AirCard 770S SIM Card Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
    • Hold the device with the charging port side facing up.
    댓글 쓰기
  2. AirCard 770S SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Look to the left of the charging port and peel back the SIM Card slot in order to open it.
    댓글 쓰기
  3. AirCard 770S SIM Card Replacement: 3 단계, 이미지 1개 중 1개
    • If there is already a SIM Card in the slot, use your finger to press in the SIM Card so that it will pop out slightly. If it does not pop out the first time, press it in again.
    • The SIM Card is not shown in picture. The red circle is where the SIM Card would be located.
    댓글 쓰기
  4. AirCard 770S SIM Card Replacement: 4 단계, 이미지 1개 중 1개
    • Use your fingers and carefully pull out the old SIM Card.
    • The SIM Card is not included in picture. The orange circle is where SIM Card would be located on the device.
    • When reassembling the device, make sure to press in the new SIM Card all the way so that the port can be closed and you can then power on the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Caitlin Little
회원 가입일: 10/08/18
437 평판
안내서 3개를 작성함
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 28
전체 시간: 2,298
