주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alan 48 Excel: Reception problems? No problem!
필요한 것
    • First of all: Power off! Switch it off and unplug the device.
    • Then grab your screwdriver and undo the screws on the housing.
    • Carefully lift off the housing and put it to one side.
    댓글 쓰기
    • Check all cables and connections. Are they properly seated?
    • Especially important: Check the connections to the antenna and the loudspeaker.
    댓글 쓰기
    • Time for some contact spray and brushes! Spray the connections thoroughly.
    • Wait a few minutes, then wipe away the residue with a clean cloth.
    댓글 쓰기
  1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: 4 단계, 이미지 1개 중 1개
    • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
    • Take your multimeter and check the transistor. If it is defective, it must be replaced.
    댓글 쓰기
  2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: 5 단계, 이미지 1개 중 1개
    • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
    • Insert the new transistor and solder it in place.
    • Check the connections with the multimeter to make sure that everything is properly working.
    댓글 쓰기
    • Put the housing back on and tighten the screws.
    • Plug in the plug, switch on the device.
    • Test whether the reception is now better.
    댓글 쓰기
결론
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Ingo Bünnemeyer
회원 가입일: 06/06/16
248 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 1,974
