주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel Jitterbug Smart Battery Replacement
필요한 것
    1. Alcatel Jitterbug Smart  Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart  Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
      • Lift open case by the corner nearest the divot and remove it from the phone.
      댓글 쓰기
    2. Alcatel Jitterbug Smart  Battery Replacement: 2 단계, 이미지 3개 중 1개 Alcatel Jitterbug Smart  Battery Replacement: 2 단계, 이미지 3개 중 2개 Alcatel Jitterbug Smart  Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
      댓글 쓰기
    3. Alcatel Jitterbug Smart  Battery Replacement: 3 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart  Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Gently pry off the Mid frame from the phone using a Metal Spudger.
      댓글 쓰기
    4. Alcatel Jitterbug Smart  Battery Replacement: 4 단계, 이미지 2개 중 1개 Alcatel Jitterbug Smart  Battery Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to pull the battery connector from its port.
      • Be careful not to tear the battery from its connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Gavin Le
회원 가입일: 02/13/18
523 평판
안내서 3개를 작성함
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 회원
USFT-CHENG-S18S11G4
4 회원들
안내서 35개를 작성함
5가이드 댓글
After reading my user guide, I searched how to replace a battery on a Jitterbug Smart2 and had several hits. I connected with this one: Alcatel Jitterbug Smart Battery Replacement 104708#. I see this is the site you have, so I began to follow instructions. When I took the back off of my phone, I saw it looks different from the one you show. Also, mine says this is a non-removeable battery. What do I do now?
Shirley Anderson - 답글 공유
I just called Great Call. They told me the battery is not replaceable. I’ll risk it anyway: What’s the point of a cordless phone that doesn’t work without a cord?
Robert L Lazzara - 답글 공유
I followed your directions step by step to remove the battery but on my Jitterbug Smart I, there are only 12 screws instead of 13! Your photo shows a screw in the middle near the camera lens but on my phone, that screw does not exist and the word void is printed in it’s place where the screw would be. Because of this, I was unable to remove the mid frame to get access to the battery. It seems to be stuck where the lens is situated making it impossible to remove and I don’t want to break it off.
Ed Johnston - 답글 공유
i'm sure it's too late for this comment to be helpful to the original poster, but the sticker that says VOID is covering the final screw and that's why it won't come off. that sticker is there so they can prove that you disassembled it and therefore voided your warranty.
David Jansen - 답글 공유
Jitterbug Smart 2 has a NON REMOVEABLE BATTERY. These bogus instructions sell a lot of U$ELE$$ batteries
Jerry Mobley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 66
전체 시간: 18,328
