주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel One Touch Evolve 2 LCD Screen Replacement
필요한 것
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: 1 단계, 이미지 3개 중 1개 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: 1 단계, 이미지 3개 중 2개 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: 1 단계, 이미지 3개 중 3개
      • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
      • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
      • Be gentle when prying so as to not wear out the tool.
      댓글 쓰기
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
      댓글 쓰기
    3. Alcatel One Touch Evolve 2 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
      댓글 쓰기
    4. Alcatel One Touch Evolve 2 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Alcatel One Touch Evolve 2 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Alcatel One Touch Evolve 2 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
      댓글 쓰기
    5. Alcatel One Touch Evolve 2 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Alcatel One Touch Evolve 2 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Pull the rear frame off with your hands.
      댓글 쓰기
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: 6 단계, 이미지 2개 중 1개 Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: 6 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pop the speaker press-fit connector free.
      • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
      댓글 쓰기
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to lift the front camera press-fit connector free.
      댓글 쓰기
    3. Alcatel One Touch Evolve 2 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
      댓글 쓰기
    4. Alcatel One Touch Evolve 2 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Detach the main circuit board from the front cover.
      댓글 쓰기
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, LCD Screen: 10 단계, 이미지 1개 중 1개
      • Gently pry off the digitizer from the main circuit board using a spudger
      댓글 쓰기
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: 11 단계, 이미지 3개 중 1개 Alcatel One Touch Evolve 2 LCD Screen Replacement: 11 단계, 이미지 3개 중 2개 Alcatel One Touch Evolve 2 LCD Screen Replacement: 11 단계, 이미지 3개 중 3개
      • Carefully separate the digitizer from circuit board.
      • Using your hands, gently remove the ribbon connecting the digitizer to the circuit board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Akira Nakaza
회원 가입일: 11/08/17
427 평판
안내서 3개를 작성함
IUPUI, Team S5-G5, Baechle Fall 2017 IUPUI, Team S5-G5, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G5
3 회원들
안내서 21개를 작성함
1가이드 댓글
Merci de nous donner l’équivalant de numériseur d'écran tactile pour Alcatel One Touch Evolve 2 4037T,l’origine est obsolète.
salut
labadi.abdelmalek - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 42
전체 시간: 1,599
