주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel One Touch Pop 7 Display Assembly Replacement
필요한 것
  1. Alcatel One Touch Pop 7 Display Assembly Replacement, Volume Button Assembly: 1 단계, 이미지 1개 중 1개
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
    댓글 쓰기
  2. Alcatel One Touch Pop 7 Display Assembly Replacement: 2 단계, 이미지 3개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 2 단계, 이미지 3개 중 2개 Alcatel One Touch Pop 7 Display Assembly Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
    댓글 쓰기
  3. Alcatel One Touch Pop 7 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
    댓글 쓰기
  4. Alcatel One Touch Pop 7 Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Alcatel One Touch Pop 7 Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
    댓글 쓰기
  5. Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: 5 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
    댓글 쓰기
  6. Alcatel One Touch Pop 7 Display Assembly Replacement: 6 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the actual camera piece from the camera slot. It may stick a bit but it shouldn't be too difficult.
    댓글 쓰기
  7. Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
    • We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
    댓글 쓰기
  8. Alcatel One Touch Pop 7 Display Assembly Replacement: 8 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable and move it out of the way of the motherboard.
    댓글 쓰기
  9. Alcatel One Touch Pop 7 Display Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Using a PH00 screwdriver to remove these seven 2mm screws and place them in a safe spot where you won't lose them.
    댓글 쓰기
  10. Alcatel One Touch Pop 7 Display Assembly Replacement: 10 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With the screws removed, you can now remove the motherboard. Using tweezers or just your fingers, pick up the motherboard and place it to the side.
    댓글 쓰기
  11. Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3개 중 2개 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3개 중 3개
    • Using a PH00 screwdriver, remove the 6 highlighted 2mm screws.
    • Pull the ribbon cables away from the back of the display screen. The right cable can be removed completely while the left will stay attached to the front casing.
    댓글 쓰기
  12. Alcatel One Touch Pop 7 Display Assembly Replacement: 12 단계, 이미지 2개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Use the plastic opening tools to pry off the plastic piece at the bottom of the device.
    댓글 쓰기
  13. Alcatel One Touch Pop 7 Display Assembly Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pull away the digitizer ribbon cable using the tweezers. It will stay attached to the front casing.
    댓글 쓰기
  14. Alcatel One Touch Pop 7 Display Assembly Replacement: 14 단계, 이미지 3개 중 1개 Alcatel One Touch Pop 7 Display Assembly Replacement: 14 단계, 이미지 3개 중 2개 Alcatel One Touch Pop 7 Display Assembly Replacement: 14 단계, 이미지 3개 중 3개
    • With the screws and ribbon cables removed, the display panel can be separated from the digitizer. You can pull the display panel away from the digitizer or turn it vertically and catch the display panel as it falls out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Riley Cooper
회원 가입일: 10/10/16
926 평판
안내서 5개를 작성함
Sam Houston State, Team 12-1, Blackburne Fall 2016 Sam Houston State, Team 12-1, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G1
3 회원들
안내서 15개를 작성함
1가이드 댓글
Hi please I will like to ask weather you have the screen in stock...am from Ghana... kindly hit me back on jamessalia11@gmail.com
Will be glad to hear from you
james salia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 52
전체 시간: 5,367
