주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel OneTouch Evolve Battery Removal
필요한 것
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: 1 단계, 이미지 1개 중 1개
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    댓글 쓰기
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 1개 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 2개 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 3개
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    댓글 쓰기
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: 3 단계, 이미지 1개 중 1개
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    댓글 쓰기
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: 4 단계, 이미지 2개 중 1개 Alcatel OneTouch Evolve Battery Removal, Removing the battery: 4 단계, 이미지 2개 중 2개
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brendan Egan
회원 가입일: 10/28/14
2,491 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 회원
UMASSD-MILES-F14S4G5
3 회원들
안내서 18개를 작성함
5가이드 댓글
Thanks 4 the info.
dennisp1964 - 답글 공유
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - 답글 공유
please replay
Thank you very much!
Kath B - 답글 공유
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 37
전체 시간: 10,558
