주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel OneTouch Evolve Camera Replacement
필요한 것
    1. Alcatel OneTouch Evolve Camera Replacement, Locate the access tab: 1 단계, 이미지 1개 중 1개
      • This will be an opening with enough space to insert the flat head of the plastic opening tool.
      • It will be located on the bottom right of the phone
      댓글 쓰기
    2. Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 1개 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 2개 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3개 중 3개
      • Rotate the pry tool 90 degrees until the panel lifts up.
      • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
      댓글 쓰기
    1. Alcatel OneTouch Evolve Camera Replacement, Identify the Battery: 3 단계, 이미지 1개 중 1개
      • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
      댓글 쓰기
    2. Alcatel OneTouch Evolve Camera Replacement, Removing the battery: 4 단계, 이미지 2개 중 1개 Alcatel OneTouch Evolve Camera Replacement, Removing the battery: 4 단계, 이미지 2개 중 2개
      • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
      댓글 쓰기
    1. Alcatel OneTouch Evolve Camera Replacement, Locate Screws Holding the Secondary Panel in Place: 5 단계, 이미지 1개 중 1개
      • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
      댓글 쓰기
    2. Alcatel OneTouch Evolve Camera Replacement, Remove Screws: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Unscrew each screw, counter-clockwise (left), until each one has been removed.
      • If necessary, use tweezers to fully remove the screws from the device.
      • Remove battery before lifting off the panel.
      댓글 쓰기
    3. Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 7 단계, 이미지 3개 중 1개 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 7 단계, 이미지 3개 중 2개 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: 7 단계, 이미지 3개 중 3개
      • Access the small pry tool in the tool kit
      • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
      • Rotate the pry tool 90 degrees until part of the panel lifts up
      • All areas need to be fully risen off before the panel can be removed.
      • Do not use the opening tool to pry open the device near the power button or near the volume button.
      댓글 쓰기
    1. Alcatel OneTouch Evolve Camera Replacement, Locate the Camera on the Device: 8 단계, 이미지 1개 중 1개
      • See yellow square for the location of the camera on the mother board.
      댓글 쓰기
    2. Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: 9 단계, 이미지 2개 중 1개 Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: 9 단계, 이미지 2개 중 2개
      • By gently lifting the bottom rectangular piece of the camera component upwards and away from the device, the connection will come free.
      • Remove the rubber casing from the camera, this piece is simply resting over the camera and can easily be removed.
      댓글 쓰기
    3. Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: 10 단계, 이미지 2개 중 1개 Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: 10 단계, 이미지 2개 중 2개
      • Place your plastic opening tool underneath the bottom of the camera and rotate the tool to lift the camera. This will take a slight amount of force.
      • You will start to see the silver sticky patch between the camera and the mother board - leave this on the mother board.
      • Keep separating the camera from the sticky patch until completely removed.
      • To replace camera, use the yellow lines on the motherboard as your guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Melissa Pijoan
회원 가입일: 10/27/14
721 평판
안내서 1개를 작성함
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 회원
UMASSD-MILES-F14S4G5
3 회원들
안내서 42개를 작성함
1가이드 댓글
Thank you kindly for your time to write the tutorial.
Tina Mccraney - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 29
전체 시간: 2,062
