주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alcatel OneTouch Pop Icon Control Buttons Replacement
필요한 것
  1. Alcatel OneTouch Pop Icon Control Buttons Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
    댓글 쓰기
  2. Alcatel OneTouch Pop Icon Control Buttons Replacement: 2 단계, 이미지 2개 중 1개 Alcatel OneTouch Pop Icon Control Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Use your thumbnail to lift the battery from the phone.
    댓글 쓰기
  3. Alcatel OneTouch Pop Icon Control Buttons Replacement, Interior Back Panel: 3 단계, 이미지 1개 중 1개
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
    댓글 쓰기
  4. Alcatel OneTouch Pop Icon Control Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
    댓글 쓰기
  5. Alcatel OneTouch Pop Icon Control Buttons Replacement, Control Buttons: 5 단계, 이미지 1개 중 1개
    • Lift the latch and gently remove the ribbon from the latch.
    댓글 쓰기
  6. Alcatel OneTouch Pop Icon Control Buttons Replacement: 6 단계, 이미지 2개 중 1개 Alcatel OneTouch Pop Icon Control Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Use the metal spudger to gently pry the control buttons from the case.
    • The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
    • Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Matthew Sheldon
회원 가입일: 04/01/16
230 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 881
