주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware 17 R2 Keyboard Replacement
필요한 것
    1. 댓글 쓰기
    2. Alienware 17 R2 Keyboard Replacement, Close the Display: 2 단계, 이미지 1개 중 1개
      • Close the display and turn the computer over.
      • Make sure PC is turned off!
      댓글 쓰기
    3. Alienware 17 R2 Keyboard Replacement, Loosen Screws: 3 단계, 이미지 1개 중 1개
      • Loosen the captive screws that secure the base panel to the computer base.
      댓글 쓰기
    4. Alienware 17 R2 Keyboard Replacement, Releasing Tabs: 4 단계, 이미지 1개 중 1개
      • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
      댓글 쓰기
    5. Alienware 17 R2 Keyboard Replacement, Remove Base Panel: 5 단계, 이미지 1개 중 1개
      • Slide and remove the base panel from the computer base.
      댓글 쓰기
    6. Alienware 17 R2 Keyboard Replacement, Disconnect Battery Cable: 6 단계, 이미지 1개 중 1개
      • Disconnect the Battery cable from the system board.
      댓글 쓰기
      • Turn the computer over.
      댓글 쓰기
      • Press and hold power button for 5 seconds to ground the system board.
      댓글 쓰기
    7. Alienware 17 R2 Keyboard Replacement, Battery Cable: 9 단계, 이미지 1개 중 1개
      • Connect the battery cable to the system board.
      댓글 쓰기
    8. Alienware 17 R2 Keyboard Replacement, Tighten Screws: 10 단계, 이미지 1개 중 1개
      • Tighten the captive screws that secure the base panel to the computer base.
      댓글 쓰기
      • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Make sure the base panel is removed.
      • Make sure palm rest is removed.
      • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
      댓글 쓰기
    1. Alienware 17 R2 Keyboard Replacement, Peel off the Cables: 12 단계, 이미지 1개 중 1개
      • Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
      댓글 쓰기
    2. Alienware 17 R2 Keyboard Replacement, Screw Removal: 13 단계, 이미지 1개 중 1개
      • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
      댓글 쓰기
      • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
      댓글 쓰기
    3. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard Bracket: 15 단계, 이미지 1개 중 1개
      • Lift the keyboard bracket off the palm-rest assembly.
      댓글 쓰기
    4. Alienware 17 R2 Keyboard Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the screws that secure the keyboard to the palm rest assembly.
      댓글 쓰기
    5. Alienware 17 R2 Keyboard Replacement, Releasing the Tabs: 17 단계, 이미지 1개 중 1개
      • Release the tabs that secure the keyboard to the palm-rest assembly.
      댓글 쓰기
    6. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard: 18 단계, 이미지 1개 중 1개
      • Slide and lift the keyboard along with the cables off the palm-rest assembly.
      댓글 쓰기
      • Slide the new keyboard under the tabs on the palm-rest assembly.
      댓글 쓰기
    7. Alienware 17 R2 Keyboard Replacement, Screw Alignment: 20 단계, 이미지 1개 중 1개
      • Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
      댓글 쓰기
      • Replace the screws that secure the keyboard to the palm-rest assembly.
      댓글 쓰기
      • Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
      댓글 쓰기
      • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
      댓글 쓰기
    8. Alienware 17 R2 Keyboard Replacement, Replace the Screws: 24 단계, 이미지 1개 중 1개
      • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
      댓글 쓰기
      • Adhere the touch-pad cable and status-light cable to the keyboard bracket.
      댓글 쓰기
      • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
80,125 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 6,888개를 작성함
1가이드 댓글
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
Sean Hanson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 48
전체 시간: 2,884
