주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware 17 R4 Battery Replacement
필요한 것
    1. Alienware 17 R4 Battery Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 2 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 3개
      • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
      • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
      • Failure to remove the battery connector cable properly may damage other parts of the laptop.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 4 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement: 4 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
      댓글 쓰기
    3. Alienware 17 R4 Battery Replacement: 5 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement: 5 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Gently lift the HDD cable to disconnect it from the laptop.
      댓글 쓰기
    4. Alienware 17 R4 Battery Replacement: 6 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the hard drive up to remove.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, RAM: 7 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement, RAM: 7 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement, RAM: 7 단계, 이미지 3개 중 3개
      • Move the metal sidings outward to release the RAM card.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Slide the RAM card out towards yourself to remove it.
      • Repeat the same step for the RAM card above.
      • Slide the RAM card out carefully to avoid damaging it.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Wi-Fi card: 9 단계, 이미지 1개 중 1개
      • Locate the WI-FI card.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 10 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 10 단계, 이미지 2개 중 2개
      • Peel back plastic cover of wi-fi card.
      • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
      댓글 쓰기
    3. Alienware 17 R4 Battery Replacement: 11 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement: 11 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement: 11 단계, 이미지 3개 중 3개
      • Gently undo the clips attached to the wi-fi card.
      • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
      댓글 쓰기
    4. Alienware 17 R4 Battery Replacement: 12 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 12 단계, 이미지 2개 중 2개
      • Locate the cables that connect the wi-fi card.
      • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Solid State Drive: 13 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement, Solid State Drive: 13 단계, 이미지 2개 중 2개
      • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 14 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 14 단계, 이미지 2개 중 2개
      • Slide the solid state drive towards yourself to prevent damage to the card.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Fan Shroud: 15 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement, Fan Shroud: 15 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement, Fan Shroud: 15 단계, 이미지 3개 중 3개
      • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 16 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 16 단계, 이미지 2개 중 2개
      • Insert the plastic opening tool under the fan shroud to slowly lift it up.
      • Repeat process on the middle and opposite side.
      댓글 쓰기
    3. Alienware 17 R4 Battery Replacement: 17 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 17 단계, 이미지 2개 중 2개
      • Firmly lift the plastic opening tool and pull the fan shroud towards you.
      • This will take a large amount of force and will not come out easily the first time.
      • Careful not to tear out the piece causing damage to the fan shroud
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Plastic Cover: 18 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement, Plastic Cover: 18 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement, Plastic Cover: 18 단계, 이미지 3개 중 3개
      • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 19 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 19 단계, 이미지 2개 중 2개
      • Follow the wiring to unplug the tron lights.
      댓글 쓰기
    3. Alienware 17 R4 Battery Replacement: 20 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement: 20 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement: 20 단계, 이미지 3개 중 3개
      • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
      댓글 쓰기
    4. Alienware 17 R4 Battery Replacement: 21 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to gently lift the sides of the cover.
      댓글 쓰기
    5. Alienware 17 R4 Battery Replacement: 22 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 22 단계, 이미지 2개 중 2개
      • Slowly lift up the plastic cover.
      댓글 쓰기
    1. Alienware 17 R4 Battery Replacement, Battery: 23 단계, 이미지 3개 중 1개 Alienware 17 R4 Battery Replacement, Battery: 23 단계, 이미지 3개 중 2개 Alienware 17 R4 Battery Replacement, Battery: 23 단계, 이미지 3개 중 3개
      • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
      댓글 쓰기
    2. Alienware 17 R4 Battery Replacement: 24 단계, 이미지 2개 중 1개 Alienware 17 R4 Battery Replacement: 24 단계, 이미지 2개 중 2개
      • Lift the battery up to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 32명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Hector Mendez III
회원 가입일: 09/11/17
1,352 평판
안내서 8개를 작성함
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G4
4 회원들
안내서 27개를 작성함
9가이드 댓글
Very good guide, just one error, step 11 comes first then step 10. You can't lift the card before remove the screw.
alex.afnet - 답글 공유
Great guide, no issues at all!
Glenn Bell - 답글 공유
First time I've cracked opened up a computer in decades. This step by step guide gave me the confidence I needed! Thank you so much. It took me longer, about two hours with stopping to label screws and things but everything is up and running again. I'm so happy!
Michelle - 답글 공유
I would not recommend disconnecting the wifi card. the connectors are tiny. if you screw up, best case you need a new wifi card, worst case you are going to need to replace the antenna, and that isn’t fun.
John Wohlwend - 답글 공유
After the battery replacement? do we need to do anything else for calibration so that the Alienware knows that it is a fresh battery and battery cycle ... as i have heard that you need to repeat 3X the process of discharging and charging for calibration. or can we just plug and play? I am getting a new battery for mine soon. Thanks =)
Yannick Docq - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 44
지난 30일: 249
전체 시간: 39,678
