주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware AW610M Scroll Wheel Replacement
필요한 것
    1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
      • Turn your mouse over with the scroll wheel facing down.
      • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
      • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
      댓글 쓰기
    2. Alienware AW610M Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 Alienware AW610M Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
      • Turn your blowdryer on a low heat setting.
      • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
      • Turn off your blowdryer, unplug the device, and set it aside to cool down.
      • Carefully peel off the stickers, and set aside as well.
      댓글 쓰기
    3. Alienware AW610M Scroll Wheel Replacement: 3 단계, 이미지 3개 중 1개 Alienware AW610M Scroll Wheel Replacement: 3 단계, 이미지 3개 중 2개 Alienware AW610M Scroll Wheel Replacement: 3 단계, 이미지 3개 중 3개
      • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
      댓글 쓰기
    4. Alienware AW610M Scroll Wheel Replacement: 4 단계, 이미지 1개 중 1개
      • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
      • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
      댓글 쓰기
    5. Alienware AW610M Scroll Wheel Replacement: 5 단계, 이미지 3개 중 1개 Alienware AW610M Scroll Wheel Replacement: 5 단계, 이미지 3개 중 2개 Alienware AW610M Scroll Wheel Replacement: 5 단계, 이미지 3개 중 3개
      • Disconnect any wire connections away from the mouse's circuit board.
      • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
      • Locate the scroll wheel placed in the gap of the mouse's backing.
      • My scroll wheel was crooked, most likely causing my issue.
      • Gently lift the scroll wheel mechanism out of the mouse's backing.
      댓글 쓰기
    6. Alienware AW610M Scroll Wheel Replacement: 6 단계, 이미지 3개 중 1개 Alienware AW610M Scroll Wheel Replacement: 6 단계, 이미지 3개 중 2개 Alienware AW610M Scroll Wheel Replacement: 6 단계, 이미지 3개 중 3개
      • Disconnect the scroll wheel sensor from the mouse backing.
      • Remove the old wheel from the plastic casing, and set it aside.
      • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
      댓글 쓰기
    7. Alienware AW610M Scroll Wheel Replacement: 7 단계, 이미지 3개 중 1개 Alienware AW610M Scroll Wheel Replacement: 7 단계, 이미지 3개 중 2개 Alienware AW610M Scroll Wheel Replacement: 7 단계, 이미지 3개 중 3개
      • Dip a cotton swab into hydrogen-peroxide.
      • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
      • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
      • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rana Ashour
회원 가입일: 04/04/23
249 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-71, Briggs Spring 2023 CSU Los Angeles, Team 2-71, Briggs Spring 2023 회원
CSULA-BRIGGS-S23S2G71
1 회원
안내서 3개를 작성함
3가이드 댓글
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - 답글 공유
Hello, I followed all the steps but I'm left with the two springs that I don't know where to put. I didn't see the two springs in your pictures.
Morar Razvan - 답글 공유
Same, did you find out where it went
ANDREW JOHNSON - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 88
지난 30일: 389
전체 시간: 16,401
