주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M11x Memory Module Replacement
필요한 것
  1. Alienware M11x Memory Module Replacement, Introduction: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    댓글 쓰기
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: 2 단계, 이미지 1개 중 1개
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    댓글 쓰기
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: 3 단계, 이미지 2개 중 1개 Alienware M11x Memory Module Replacement, Removing the Memory Module: 3 단계, 이미지 2개 중 2개
    • Remove the memory module from the memory module connector.
    댓글 쓰기
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: 4 단계, 이미지 1개 중 1개
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
    댓글 쓰기
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: 5 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 43
전체 시간: 801
