주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M14xR2 Hard Drive Replacement
필요한 것
  1. Alienware M14xR2 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    댓글 쓰기
  2. Alienware M14xR2 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Alienware M14xR2 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Alienware M14xR2 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    댓글 쓰기
  3. Alienware M14xR2 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    댓글 쓰기
  4. Alienware M14xR2 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Alienware M14xR2 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Alienware M14xR2 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    댓글 쓰기
  5. Alienware M14xR2 Hard Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 1개 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 2개 Alienware M14xR2 Hard Drive Replacement, Optical Drive: 5 단계, 이미지 3개 중 3개
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    댓글 쓰기
  6. Alienware M14xR2 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2개 중 1개 Alienware M14xR2 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2개 중 2개
    • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
    • The screws are spring loaded and will not come loose from the hard drive assembly.
    • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
    댓글 쓰기
  7. Alienware M14xR2 Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 Alienware M14xR2 Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
    • Set aside the now disconnected hard drive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Connor Bovee
회원 가입일: 09/30/13
569 평판
안내서 2개를 작성함
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 회원
CPSU-FORTE-F13S13G4
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 60
전체 시간: 11,726
