주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M14xR2 RAM Replacement
필요한 것
  1. Alienware M14xR2 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    댓글 쓰기
  2. Alienware M14xR2 RAM Replacement: 2 단계, 이미지 3개 중 1개 Alienware M14xR2 RAM Replacement: 2 단계, 이미지 3개 중 2개 Alienware M14xR2 RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    댓글 쓰기
  3. Alienware M14xR2 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    댓글 쓰기
  4. Alienware M14xR2 RAM Replacement: 4 단계, 이미지 3개 중 1개 Alienware M14xR2 RAM Replacement: 4 단계, 이미지 3개 중 2개 Alienware M14xR2 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    댓글 쓰기
  5. Alienware M14xR2 RAM Replacement, Optical Drive: 5 단계, 이미지 3개 중 1개 Alienware M14xR2 RAM Replacement, Optical Drive: 5 단계, 이미지 3개 중 2개 Alienware M14xR2 RAM Replacement, Optical Drive: 5 단계, 이미지 3개 중 3개
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    댓글 쓰기
  6. Alienware M14xR2 RAM Replacement, RAM: 6 단계, 이미지 3개 중 1개 Alienware M14xR2 RAM Replacement, RAM: 6 단계, 이미지 3개 중 2개 Alienware M14xR2 RAM Replacement, RAM: 6 단계, 이미지 3개 중 3개
    • Unscrew the two 6.35 mm size 1 screws.
    • Lift up and remove the panel covering the RAM sticks.
    댓글 쓰기
  7. Alienware M14xR2 RAM Replacement: 7 단계, 이미지 2개 중 1개 Alienware M14xR2 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Push outward on both prongs that secure the RAM sticks in place.
    • The RAM sticks will rise upward when released from the prongs.
    댓글 쓰기
  8. Alienware M14xR2 RAM Replacement: 8 단계, 이미지 2개 중 1개 Alienware M14xR2 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Grab and pull the RAM sticks up and out of their casing and set them aside.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Eugene Park
회원 가입일: 09/30/13
195 평판
안내서 1개를 작성함
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 회원
CPSU-FORTE-F13S13G4
5 회원들
안내서 6개를 작성함
3가이드 댓글
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - 답글 공유
I meaned r1 model
doantuan85 - 답글 공유
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 30
전체 시간: 2,685
