주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M15x Memory Modules Replacement
필요한 것
    1. Alienware M15x Memory Modules Replacement, Turn the Computer: 1 단계, 이미지 1개 중 1개
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • Turn the computer over.
      댓글 쓰기
    2. Alienware M15x Memory Modules Replacement, Sliding the Battery: 2 단계, 이미지 1개 중 1개
      • Slide the battery latch to the unlock position as shown.
      댓글 쓰기
    3. Alienware M15x Memory Modules Replacement, Removing the Battery Pack: 3 단계, 이미지 1개 중 1개
      • After the Battery Pack pops up, remove the Battery Pack.
      댓글 쓰기
    4. Alienware M15x Memory Modules Replacement, Aligning the Battery Pack Tabs: 4 단계, 이미지 1개 중 1개
      • Align the battery pack tabs with the slots in the battery bay.
      댓글 쓰기
    5. Alienware M15x Memory Modules Replacement, Pushing the Battery Pack: 5 단계, 이미지 1개 중 1개
      • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
      댓글 쓰기
    1. Alienware M15x Memory Modules Replacement, Loosen the Screws: 6 단계, 이미지 1개 중 1개
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Loosen the two captive screws that secure the memory-module door to the computer base.
      댓글 쓰기
    2. Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: 7 단계, 이미지 2개 중 1개 Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: 7 단계, 이미지 2개 중 2개
      • Slide the memory-module door to release the tabs and lift the memory-module door out of the computer base.
      댓글 쓰기
    3. Alienware M15x Memory Modules Replacement, Popping up the Memory Module: 8 단계, 이미지 2개 중 1개 Alienware M15x Memory Modules Replacement, Popping up the Memory Module: 8 단계, 이미지 2개 중 2개
      • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
      • CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
      • Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
      댓글 쓰기
    4. Alienware M15x Memory Modules Replacement, Remove the Memory Module: 9 단계, 이미지 1개 중 1개
      • Remove the memory module.
      댓글 쓰기
    5. Alienware M15x Memory Modules Replacement, Align the Notch: 10 단계, 이미지 3개 중 1개 Alienware M15x Memory Modules Replacement, Align the Notch: 10 단계, 이미지 3개 중 2개 Alienware M15x Memory Modules Replacement, Align the Notch: 10 단계, 이미지 3개 중 3개
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      댓글 쓰기
    6. Alienware M15x Memory Modules Replacement, Insert the Module: 11 단계, 이미지 2개 중 1개 Alienware M15x Memory Modules Replacement, Insert the Module: 11 단계, 이미지 2개 중 2개
      • Insert the module into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
      댓글 쓰기
    7. Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: 12 단계, 이미지 2개 중 1개 Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: 12 단계, 이미지 2개 중 2개
      • CAUTION: If the memory-module door is difficult to close, remove the memory module and reinstall it. Forcing the memory-module door to close may damage your computer.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      • Align and insert the memory-module door tabs into the slots on the computer base.
      댓글 쓰기
    8. Alienware M15x Memory Modules Replacement, Replacing and Tightening the Screws: 13 단계, 이미지 1개 중 1개
      • Replace and tighten the two captive screws that secure the memory-module door to the computer base.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
80,125 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 6,888개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 34
전체 시간: 637
