주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M17x Display Assembly Replacement
필요한 것
  1. Alienware M17x Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Alienware M17x Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    댓글 쓰기
  2. Alienware M17x Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    댓글 쓰기
  3. Alienware M17x Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    댓글 쓰기
  4. Alienware M17x Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 Alienware M17x Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    댓글 쓰기
  5. Alienware M17x Display Assembly Replacement, Display Assembly: 5 단계, 이미지 1개 중 1개
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
    댓글 쓰기
  6. Alienware M17x Display Assembly Replacement: 6 단계, 이미지 3개 중 1개 Alienware M17x Display Assembly Replacement: 6 단계, 이미지 3개 중 2개 Alienware M17x Display Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
    댓글 쓰기
  7. Alienware M17x Display Assembly Replacement: 7 단계, 이미지 2개 중 1개 Alienware M17x Display Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the screen from the top mount.
    댓글 쓰기
  8. Alienware M17x Display Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
    댓글 쓰기
  9. Alienware M17x Display Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mosier Locke
회원 가입일: 09/27/18
783 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 31
전체 시간: 981
