주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M17x Motherboard Replacement
필요한 것
  1. Alienware M17x Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Alienware M17x Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    댓글 쓰기
  2. Alienware M17x Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    댓글 쓰기
  3. Alienware M17x Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    댓글 쓰기
  4. Alienware M17x Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Alienware M17x Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    댓글 쓰기
  5. Alienware M17x Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
    • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
    • Twelve 5.5 mm Phillips #0 main frame screws.
    • Six 3.5 mm Phillips #0 fan screws.
    • Four 3.5 mm Phillips #0 internal compartment screws.
    • Eight 3.5 mm Phillips #0 Hard Drive screws.
    • Four 3.5 mm Phillips #0 CD Drive screws.
    • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
    댓글 쓰기
  6. Alienware M17x Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Alienware M17x Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Alienware M17x Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the computer.
    댓글 쓰기
  7. Alienware M17x Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove five 3.5 mm Phillips #0 screws from the motherboard.
    • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
    • Lift the motherboard at an angle and remove it from the computer base.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mosier Locke
회원 가입일: 09/27/18
783 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 27
전체 시간: 2,444
