주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware Pro Wireless Gaming Mouse Optical Lens Replacement
필요한 것
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 1 단계, 이미지 3개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 1 단계, 이미지 3개 중 2개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Feet: 1 단계, 이미지 3개 중 3개
      • Flip the mouse over so the bottom is facing up..
      • Use an opening pick to gently peel the mouse foot off the bottom case.
      • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
      댓글 쓰기
    2. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 2 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 2 단계, 이미지 2개 중 2개
      • Peel and remove the other mouse foot.
      댓글 쓰기
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
      댓글 쓰기
    2. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 4 단계, 이미지 3개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 4 단계, 이미지 3개 중 2개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 4 단계, 이미지 3개 중 3개
      • Use your hands or a spudger to separate the bottom and top of the mouse.
      • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
      • You may hear a cracking sound when the clips are released.
      댓글 쓰기
    3. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 5 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 5 단계, 이미지 2개 중 2개
      • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
      댓글 쓰기
    4. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 6 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 6 단계, 이미지 2개 중 2개
      • The battery is glued to the case.
      • Use an opening tool or spudger to loosen the adhesive under the battery.
      • Remove the battery.
      댓글 쓰기
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Side Button: 7 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Side Button: 7 단계, 이미지 2개 중 2개
      • Pinch the upper part of the ribbon cable.
      • Pull the ribbon cable gently to detach it from the socket on the motherboard.
      • Make sure the ribbon line is facing the correct direction when reassembling the controller.
      댓글 쓰기
    2. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 8 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the side button panel from the plastic frame.
      댓글 쓰기
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 9 단계, 이미지 3개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 9 단계, 이미지 3개 중 2개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Scroll Wheel: 9 단계, 이미지 3개 중 3개
      • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
      • Only light force is needed—be gentle to avoid damaging nearby parts.
      댓글 쓰기
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
      댓글 쓰기
    2. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Gently pull the side clip away from the motherboard to release it from the plastic frame.
      • Use a spudger to release the board from the clips if that is easier.
      댓글 쓰기
    3. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 12 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement: 12 단계, 이미지 2개 중 2개
      • Bend the front nose of the mouse body to release the motherboard.
      • Remove the motherboard from the bottom case.
      댓글 쓰기
    1. Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Optical Lens: 13 단계, 이미지 2개 중 1개 Alienware Pro Wireless Gaming Mouse Optical Lens Replacement, Optical Lens: 13 단계, 이미지 2개 중 2개
      • On the bottom of the motherboard, remove the clear plastic lens.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Samuel Blanton
회원 가입일: 09/29/25
363 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 156
