주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware X51 R2/R3 CPU Replacement
필요한 것
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): 1 단계, 이미지 1개 중 1개
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
    댓글 쓰기
  2. Alienware X51 R2/R3 CPU Replacement: 2 단계, 이미지 1개 중 1개
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
    댓글 쓰기
  3. Alienware X51 R2/R3 CPU Replacement: 3 단계, 이미지 1개 중 1개
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
    댓글 쓰기
  4. Alienware X51 R2/R3 CPU Replacement: 4 단계, 이미지 1개 중 1개
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
    댓글 쓰기
  5. Alienware X51 R2/R3 CPU Replacement: 5 단계, 이미지 1개 중 1개
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
rcschwartz709
회원 가입일: 07/02/16
220 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 53
전체 시간: 3,246
