주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Allow Code42 (Crashplan) Access to Backup Personal Files
    1. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Apple System Preferences: 1 단계, 이미지 1개 중 1개
      • Click in the Apple logo in the top left hand corner of the screen, then select "System Preferences"
      댓글 쓰기
    2. Allow Code42 (Crashplan) Access to Backup Personal Files, Open Security and Privacy: 2 단계, 이미지 1개 중 1개
      • Select "Security and Privacy"
      댓글 쓰기
    3. Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 3 단계, 이미지 3개 중 1개 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 3 단계, 이미지 3개 중 2개 Allow Code42 (Crashplan) Access to Backup Personal Files, Select the Privacy Tab: 3 단계, 이미지 3개 중 3개
      • If necessary, unlock the preference pane by clicking on the padlock in the lower left corner of the window, then enter your password. Once the padlock icon is in the open position, select the "Privacy" tab
      • Once in the Privacy tab, Scroll through the box on the left and select "Full Disk Access"
      • Check the box next to "Code42" in the "Full Disk Access" settings pane to allow Crashplan to backup your personal files.
      • The following message appears: "Code42" will not have full disk access until it is quit. Click Quit Now.
      댓글 쓰기
    4. Allow Code42 (Crashplan) Access to Backup Personal Files, Restart Your Mac: 4 단계, 이미지 1개 중 1개
      • Though not strictly necessary, it is good practice to restart your computer to allow the changes you've made to take effect. The next time Code42 launches, it should have the permission it needs to access your home folder and backup your Desktop, Documents, Mail, Contacts, Photos, and more.
      • For more information on this change, see Code42's documentation at: https://support.code42.com/CrashPlan/6/T...
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kevin Tully
회원 가입일: 10/14/19
149 평판
안내서 1개를 작성함
1가이드 댓글
Great!! Thanks Kevin!
dahernandezs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 49
전체 시간: 1,968
