주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AlphaSmart Pro Display Screen Replacement
필요한 것
  1. AlphaSmart Pro Display Screen Replacement, Separating Panels: 1 단계, 이미지 3개 중 1개 AlphaSmart Pro Display Screen Replacement, Separating Panels: 1 단계, 이미지 3개 중 2개 AlphaSmart Pro Display Screen Replacement, Separating Panels: 1 단계, 이미지 3개 중 3개
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    댓글 쓰기
  2. AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 1개 AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 2개
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
    댓글 쓰기
  3. AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 1개 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 2개 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 3개
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
    댓글 쓰기
  4. AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 4 단계, 이미지 3개 중 1개 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 4 단계, 이미지 3개 중 2개 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • To remove the small motherboard from the display screen, use the flat needle nose pliers or the angled tweezers to carefully bend the 12 metal tabs so that they can be pushed through the small slots.
    • You must also lift up the transparent tape that covers two of these tabs.
    • Separate the display screen and small motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Nathan Smith
회원 가입일: 10/13/14
22 평판
안내서 2개를 작성함
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 44
전체 시간: 1,068
