주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AlphaSmart Pro Front Panel Replacement
필요한 것
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: 1 단계, 이미지 3개 중 1개 AlphaSmart Pro Front Panel Replacement, Separating Panels: 1 단계, 이미지 3개 중 2개 AlphaSmart Pro Front Panel Replacement, Separating Panels: 1 단계, 이미지 3개 중 3개
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    댓글 쓰기
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 1개 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 2개
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
    댓글 쓰기
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 1개 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 2개 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: 3 단계, 이미지 3개 중 3개
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Nathan Smith
회원 가입일: 10/13/14
22 평판
안내서 2개를 작성함
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 559
