주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AlphaSmart Pro Individual Key Replacement
필요한 것
  1. AlphaSmart Pro Individual Key Replacement, Removing a Key: 1 단계, 이미지 2개 중 1개 AlphaSmart Pro Individual Key Replacement, Removing a Key: 1 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up.
    • You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
    댓글 쓰기
  2. AlphaSmart Pro Individual Key Replacement, The Spacebar Spring: 2 단계, 이미지 1개 중 1개
    • If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
    • Remove the spring and place it to the side so it doesn't get lost.
    • It does not matter which of the two circular spots the spring is on.
    • There is only one spring per spacebar. If the spring is missing, don't worry — the spacebar will work fine without it — but it will work better when the spring is attached.
    댓글 쓰기
  3. AlphaSmart Pro Individual Key Replacement, Removing Other Keys: 3 단계, 이미지 1개 중 1개
    • If you wish to remove another key besides the spacebar, the same methods of removal apply.
    • You should hear a "popping" or "snapping" sound when the key has been removed.
    • Unlike the spacebar key, all the other keys do not have a spring.
    댓글 쓰기
  4. AlphaSmart Pro Individual Key Replacement, Replacement: 4 단계, 이미지 2개 중 1개 AlphaSmart Pro Individual Key Replacement, Replacement: 4 단계, 이미지 2개 중 2개
    • To replace the key(s), simply align the center cylindrical post(s) with the center holes.
    • Use your index finger to press down on the middle of the key. You should hear it "click" into place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Katy Beth Culp
회원 가입일: 10/13/14
1 평판
안내서 2개를 작성함
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 2,020
