주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AlphaSmart Pro Lithium Coin Battery Replacement
필요한 것
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 2개 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: 1 단계, 이미지 3개 중 3개
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    댓글 쓰기
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: 2 단계, 이미지 2개 중 2개
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    댓글 쓰기
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: 3 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: 3 단계, 이미지 2개 중 2개
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
    댓글 쓰기
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: 4 단계, 이미지 2개 중 1개 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: 4 단계, 이미지 2개 중 2개
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Katy Beth Culp
회원 가입일: 10/13/14
1 평판
안내서 2개를 작성함
Clemson, Team 1-1, Benson Fall 2014 Clemson, Team 1-1, Benson Fall 2014 회원
CLEM-BENSON-F14S1G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 54
전체 시간: 1,382
