주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Altec Lansing BoomJacket 2 Battery Replacement
필요한 것
    1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 2개
      • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
      댓글 쓰기
    2. Altec Lansing BoomJacket 2 Battery Replacement: 2 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
      댓글 쓰기
    3. Altec Lansing BoomJacket 2 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
      • Avoid using excessive force to prevent bending the grill.
      댓글 쓰기
    4. Altec Lansing BoomJacket 2 Battery Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Battery Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
      댓글 쓰기
    5. Altec Lansing BoomJacket 2 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
      댓글 쓰기
    6. Altec Lansing BoomJacket 2 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Gently pull apart the front panel from the base of the speaker.
      댓글 쓰기
    1. Altec Lansing BoomJacket 2 Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
      • The battery will be in the middle of the speaker when the case is open.
      댓글 쓰기
    2. Altec Lansing BoomJacket 2 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
      • Pull battery up and away from speaker without catching any other components.
      • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zach Braaten
회원 가입일: 07/12/18
561 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 2,074
