주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Altec Lansing BoomJacket 2 Motherboard Replacement
필요한 것
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: 1 단계, 이미지 2개 중 2개
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
    댓글 쓰기
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
    댓글 쓰기
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
    댓글 쓰기
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
    댓글 쓰기
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
    댓글 쓰기
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull apart the front panel from the base of the speaker.
    댓글 쓰기
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • The battery will be in the middle of the speaker when the case is open.
    댓글 쓰기
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
    댓글 쓰기
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
    댓글 쓰기
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
    댓글 쓰기
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Zach Braaten
회원 가입일: 07/12/18
537 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G4, Cardinal Summer 2018 UW Tacoma, Team S1-G4, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G4
4 회원들
안내서 4개를 작성함
1가이드 댓글
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 26
전체 시간: 1,211
