주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo 2nd Generation AMP Board Replacement
필요한 것
    1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 1 단계, 이미지 3개 중 1개 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 1 단계, 이미지 3개 중 2개 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: 1 단계, 이미지 3개 중 3개
      • Remove the rubber layer beneath the device.
      • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
      • Remove the four 8.0 mm T8 Torx screws on the lid.
      • Remove the lid from the device.
      댓글 쓰기
    2. Amazon Echo 2nd Generation AMP Board Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo 2nd Generation AMP Board Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo 2nd Generation AMP Board Replacement: 2 단계, 이미지 3개 중 3개
      • Use a spudger to flip up the small flap on the ZIF connector.
      • Gently pull the ribbon cable out of the ZIF connector.
      • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
      댓글 쓰기
    3. Amazon Echo 2nd Generation AMP Board Replacement: 3 단계, 이미지 2개 중 1개 Amazon Echo 2nd Generation AMP Board Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to lift up one of the small flaps on only one side of the female connector.
      • Pull on the wire toward the lifted side until the male connector is disconnected.
      • Remove the AMP Board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Eric Inman
회원 가입일: 10/08/18
337 평판
안내서 3개를 작성함
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 회원
CPSU-WHITE-F18S4G4
3 회원들
안내서 15개를 작성함
4가이드 댓글
Can anyone find a replacement board?
Tristan Parks - 답글 공유
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - 답글 공유
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - 답글 공유
I have a need of one such a bord
Attmaram Nagorao Sugandhe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 87
전체 시간: 5,189
