주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo 2nd Generation Speaker Replacement
필요한 것
    1. Amazon Echo 2nd Generation Speaker Replacement, AMP Board: 1 단계, 이미지 3개 중 1개 Amazon Echo 2nd Generation Speaker Replacement, AMP Board: 1 단계, 이미지 3개 중 2개 Amazon Echo 2nd Generation Speaker Replacement, AMP Board: 1 단계, 이미지 3개 중 3개
      • Remove the rubber layer beneath the device.
      • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
      • Remove the four 8.0 mm T8 Torx screws on the lid.
      • Remove the lid from the device.
      댓글 쓰기
    2. Amazon Echo 2nd Generation Speaker Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo 2nd Generation Speaker Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo 2nd Generation Speaker Replacement: 2 단계, 이미지 3개 중 3개
      • Use a spudger to flip up the small flap on the ZIF connector.
      • Gently pull the ribbon cable out of the ZIF connector.
      • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
      댓글 쓰기
    3. Amazon Echo 2nd Generation Speaker Replacement: 3 단계, 이미지 2개 중 1개 Amazon Echo 2nd Generation Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to lift up one of the small flaps on only one side of the female connector.
      • Pull on the wire toward the lifted side until the male connector is disconnected.
      • Remove the AMP Board.
      댓글 쓰기
    1. Amazon Echo 2nd Generation Speaker Replacement, Subwoofer (speaker): 4 단계, 이미지 2개 중 1개 Amazon Echo 2nd Generation Speaker Replacement, Subwoofer (speaker): 4 단계, 이미지 2개 중 2개
      • Remove the four 30.0 mm T8 Torx screws in the corners.
      • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
      댓글 쓰기
    2. Amazon Echo 2nd Generation Speaker Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo 2nd Generation Speaker Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the lid on top of the subwoofer.
      • Flip the device over and let the subwoofer fall into your hand.
      • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric Inman
회원 가입일: 10/08/18
337 평판
안내서 3개를 작성함
Cal Poly, Team S4-G4, White Fall 2018 Cal Poly, Team S4-G4, White Fall 2018 회원
CPSU-WHITE-F18S4G4
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 79
전체 시간: 4,992
