주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Motherboard Replacement
필요한 것
    1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: 1 단계, 이미지 1개 중 1개
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      댓글 쓰기
    2. Amazon Echo Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      댓글 쓰기
    3. Amazon Echo Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      댓글 쓰기
    4. Amazon Echo Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      댓글 쓰기
    5. Amazon Echo Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      댓글 쓰기
    6. Amazon Echo Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      댓글 쓰기
    1. Amazon Echo Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Amazon Echo Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      댓글 쓰기
    2. Amazon Echo Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Peel off the black fabric wrapped around the device.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      댓글 쓰기
    3. Amazon Echo Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Amazon Echo Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the four 9.7 mm T10 screws.
      댓글 쓰기
    4. Amazon Echo Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Amazon Echo Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Amazon Echo Motherboard Replacement: 10 단계, 이미지 3개 중 3개
      • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
      • Pull the two ribbon cables from their connectors on the motherboard.
      댓글 쓰기
    5. Amazon Echo Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • Lift the motherboard up from the Echo.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alexander Albert
회원 가입일: 02/04/16
1,169 평판
안내서 6개를 작성함
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G3
4 회원들
안내서 25개를 작성함
11가이드 댓글
Where can you get the mmotherboard
Glen Seay - 답글 공유
same question. where do i get replacement motherboard?
akn978s - 답글 공유
This is how to remove the motherboard not how to replace it....geez
adairt - 답글 공유
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - 답글 공유
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 117
전체 시간: 16,553
