소개
This guide will walk you through the replacement process for the microphone component found within your Amazon Echo Show 10 3rd Gen device. The microphone is responsible for taking in voice commands for the device to respond to as well as receiving audio during calls. In the event that the microphone board within the device is malfunctioning or damaged, the device (and its Alexa Assistant) may not be responding to voice commands or may not be able to hear them very well; replacement of this component may be necessary if this is the case.
Ensure that the microphone is properly turned on with both the physical microphone button and in the settings before committing to disassembly. Please make sure to check the other solutions listed in the Amazon Echo Show 10 3rd Gen troubleshooting page before replacement.
This replacement guide requires the user to pry and remove multiple adhesive components. The extended duration of this guide is due to the significant number of small parts that need to be disassembled, rather than the complexity of the disassembly itself
필요한 것
With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set aside.
Insert a Jimmy along the seam of the screen and the shell and slide it along the length to separate the two sides.
