주요 콘텐츠로 건너뛰기
Amazon Echo Show 10 3rd Gen Woofer Replacement
필요한 것
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: 1 단계, 이미지 1/2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: 1 단계, 이미지 2/2
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: 3 단계, 이미지 1/2 Amazon Echo Show 10 3rd Gen Woofer Replacement: 3 단계, 이미지 2/2
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: 4 단계, 이미지 1/1
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: 5 단계, 이미지 1/1
    • After desoldering the three cables, lift the woofer out of the shell of the device.
결론
Macy Ormand
회원 가입일: 09/13/23
1,073 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 92
