주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show 15 Buttons Replacement
필요한 것
  1. Amazon Echo Show 15 Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    댓글 쓰기
  2. Amazon Echo Show 15 Buttons Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    댓글 쓰기
  3. Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 3 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 3 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement, Inner Black Panel: 3 단계, 이미지 3개 중 3개
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
    댓글 쓰기
  4. Amazon Echo Show 15 Buttons Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
    • Take off the metal protector.
    • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
    • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
    댓글 쓰기
  5. Amazon Echo Show 15 Buttons Replacement: 5 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement: 5 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Detach the connectors for the camera and buttons from the motherboard.
    • Detach the connectors for the power station and speakers from the motherboard.
    • Detach the small white coaxial cables from the motherboard.
    • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
    댓글 쓰기
  6. Amazon Echo Show 15 Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the motherboard from the main device.
    댓글 쓰기
  7. Amazon Echo Show 15 Buttons Replacement, Buttons: 7 단계, 이미지 3개 중 1개 Amazon Echo Show 15 Buttons Replacement, Buttons: 7 단계, 이미지 3개 중 2개 Amazon Echo Show 15 Buttons Replacement, Buttons: 7 단계, 이미지 3개 중 3개
    • Remove the three 3 mm screws from the green panel in the top right-hand corner of the device using a Phillips #1 screwdriver.
    • Remove the green panel.
    • The green panel is connected to the main device with adhesive. You will need to use a bit more force to get it out.
    댓글 쓰기
  8. Amazon Echo Show 15 Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the rubber part of the buttons.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Julia Silvestrin
회원 가입일: 09/20/23
291 평판
안내서 2개를 작성함
Utah Tech University, Team 1-4, McMurrin Fall 2023 Utah Tech University, Team 1-4, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G4
3 회원들
안내서 14개를 작성함
1가이드 댓글
I bet this is what I need to do, I’ve cleaned motherboards with the rubber push pads on snow plow controls I’ve had my pickup. Like Red Bull, coffee, spills that snuck their way in( gross) but after cleaning and or letting things air out, back in biz.buying the driver kit tomorrow thank you very much for being so clever two yrs ago! And the heads up about adhesive thanks. I miss my Show 15
All my daughter’s pics and all that jazz, miss seeing it everyday. Thank You !!🌳
Treeman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 38
전체 시간: 627
