주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show 2nd Gen Button Replacement
필요한 것
  1. Amazon Echo Show 2nd Gen Button Replacement, Sound foam: 1 단계, 이미지 3개 중 1개 Amazon Echo Show 2nd Gen Button Replacement, Sound foam: 1 단계, 이미지 3개 중 2개 Amazon Echo Show 2nd Gen Button Replacement, Sound foam: 1 단계, 이미지 3개 중 3개
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
    댓글 쓰기
  2. Amazon Echo Show 2nd Gen Button Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Show 2nd Gen Button Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Show 2nd Gen Button Replacement: 2 단계, 이미지 3개 중 3개
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
    댓글 쓰기
  3. Amazon Echo Show 2nd Gen Button Replacement, Button: 3 단계, 이미지 2개 중 1개 Amazon Echo Show 2nd Gen Button Replacement, Button: 3 단계, 이미지 2개 중 2개
    • Firmly grasp the white trim of the front piece with one hand while the other pulls back on the black back portion of the device.
    댓글 쓰기
  4. Amazon Echo Show 2nd Gen Button Replacement: 4 단계, 이미지 3개 중 1개 Amazon Echo Show 2nd Gen Button Replacement: 4 단계, 이미지 3개 중 2개 Amazon Echo Show 2nd Gen Button Replacement: 4 단계, 이미지 3개 중 3개
    • Remove all of the red 2 mm screws using a T5 torx screwdriver.
    • Carefully lift away the metal plate.
    댓글 쓰기
  5. Amazon Echo Show 2nd Gen Button Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Show 2nd Gen Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using a T5 torx screwdriver, remove all 2 mm screws from the motherboard.
    • Remove all orange marked screws from the second metal plate.
    댓글 쓰기
  6. Amazon Echo Show 2nd Gen Button Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Show 2nd Gen Button Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Show 2nd Gen Button Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the motherboard from the device. Be sure to be careful when removing the black adhesive.
    댓글 쓰기
  7. Amazon Echo Show 2nd Gen Button Replacement: 7 단계, 이미지 3개 중 1개 Amazon Echo Show 2nd Gen Button Replacement: 7 단계, 이미지 3개 중 2개 Amazon Echo Show 2nd Gen Button Replacement: 7 단계, 이미지 3개 중 3개
    • Remove all 2 mm screws that are attached to the black plastic button casing.
    • Remove the case that holds the buttons. Buttons should now be free to remove.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Kara Funke
회원 가입일: 01/24/20
136 평판
안내서 1개를 작성함
Group 02 ERAU - Echo Show Group 02 ERAU - Echo Show 회원
Local Repair Groups
2 회원들
안내서 2개를 작성함
1가이드 댓글
These instructions are missing one important step, at least on my version of the Echo Show 10 2nd gen. There are 8 Tr8 screws holding the big black backside with the speakers + sound card in place 4 at the top, 2 on each side and 2 at the bottom.
These 8 screws need to be removed before separating the back from the front in Step 3 of this guide.
To get to the 2 screws at the bottom the white cover which covers the sound-card and the connectors on the back needs to be removed as is described in the Sound Card replacement guide. Note the white cover is not only attached with 6 tr1 screws there also is some double-sided tape holding it in place at the edge near the power-connector you can see the tape remains at the first Picture of step 3 of the Sound Card replacement guide.
Since the white cover needs to be removed anyways it is easier to remove the cables to the sound card on the sound card side, as is shown in step 5 of the Sound Card replacement guide.
Hans de Goede - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 40
전체 시간: 996
