주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show 5-Megapixel Camera Replacement
필요한 것
  1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 1 단계, 이미지 2개 중 1개 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: 1 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to gently lift the plastic protector from the screen.
    댓글 쓰기
  2. Amazon Echo Show 5-Megapixel Camera  Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Show 5-Megapixel Camera  Replacement: 2 단계, 이미지 2개 중 2개
    • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
    댓글 쓰기
  3. Amazon Echo Show 5-Megapixel Camera  Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
    댓글 쓰기
  4. Amazon Echo Show 5-Megapixel Camera  Replacement: 4 단계, 이미지 3개 중 1개 Amazon Echo Show 5-Megapixel Camera  Replacement: 4 단계, 이미지 3개 중 2개 Amazon Echo Show 5-Megapixel Camera  Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Lay the front section flat, with the screen down.
    댓글 쓰기
  5. Amazon Echo Show 5-Megapixel Camera  Replacement: 5 단계, 이미지 3개 중 1개 Amazon Echo Show 5-Megapixel Camera  Replacement: 5 단계, 이미지 3개 중 2개 Amazon Echo Show 5-Megapixel Camera  Replacement: 5 단계, 이미지 3개 중 3개
    • Remove two 1mm T5 Torx screws.
    • Once the screws have been removed, you can easily remove the camera from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
1가이드 댓글
Can not reset amazon echo show model MW46WB tried everything any suggestions
Skippy Gessler - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 35
전체 시간: 2,549
