주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show Back Cover Replacement
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Amazon Echo Show Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Amazon Echo Show Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Using your hands, gently remove the taped-in rubber foot from device.
    댓글 쓰기
  2. Amazon Echo Show Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Show Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
    댓글 쓰기
  3. Amazon Echo Show Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
    댓글 쓰기
  4. Amazon Echo Show Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Show Back Cover Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Repeat this step for the other speaker, and lay the front section flat with the facing down.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
2가이드 댓글
this particular guide originally only had the prerequisite guide portion, so the steps to replace the top buttons were repeated across every single guide we had. I adjusted the prerequisite guide to include the separation of the two halves and moved the top button replacement guide to its own page. As this is still a private guide, it won’t be published unless we approve it.
Justin Williams - 답글 공유
This article has been flagged as the prerequisite guide for a few of our articles, so I ended up altering it to be such. However, the ones that are not linked to this one, I added a few steps.
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 17
전체 시간: 642
