주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Show Speaker Replacement
필요한 것
    1. Amazon Echo Show Speaker Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Amazon Echo Show Speaker Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Using your hands, gently remove the taped-in rubber foot from device.
      댓글 쓰기
    2. Amazon Echo Show Speaker Replacement: 2 단계, 이미지 2개 중 1개 Amazon Echo Show Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Carefully peel off the bottom pad to expose the fastening screws.
      • Remove three silver 1.4 T5 Torx screws on the top row.
      • Remove one green 1mm T5 Torx screw in the middle.
      • Remove a black 1.5mm T5 screw.
      • Remove three green 1mm T5 screws from the bottom row.
      댓글 쓰기
    3. Amazon Echo Show Speaker Replacement: 3 단계, 이미지 1개 중 1개
      • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
      댓글 쓰기
    4. Amazon Echo Show Speaker Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Show Speaker Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
      • Repeat this step for the other speaker, and lay the front section flat with the facing down.
      • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
      댓글 쓰기
    1. Amazon Echo Show Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 1개 Amazon Echo Show Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 2개 Amazon Echo Show Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 3개
      • Use a non-magnetic T-6 screwdriver to unscrew the four 6mm screws on the speaker mount.
      • Repeat this step for the other speaker.
      댓글 쓰기
    2. Amazon Echo Show Speaker Replacement: 6 단계, 이미지 2개 중 1개 Amazon Echo Show Speaker Replacement: 6 단계, 이미지 2개 중 2개
      • Gently lift the speaker needing replacement from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
2가이드 댓글
Seems you missed an important step on here. How do you get the front off the box? Show how to remove the speaker grill, the grill cloth and then pry up the digitizer and screen. That’s where all the f***ing screws are!!! That’s how you get into this damned thing!! But you left all that ‘unimportant’ stuff out.
n3tqv - 답글 공유
Where do you get a replacement speakers
bluwolf224 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 46
전체 시간: 6,970
