주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Studio Motherboard Replacement
필요한 것
    1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement, Power Supply Board: 1 단계, 이미지 3개 중 3개
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      댓글 쓰기
    2. Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      댓글 쓰기
    3. Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Before fully removing the base, remove the three attached connectors.
      댓글 쓰기
    4. Amazon Echo Studio Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      댓글 쓰기
    1. Amazon Echo Studio Motherboard Replacement, Subwoofer: 5 단계, 이미지 1개 중 1개
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      댓글 쓰기
    2. Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      댓글 쓰기
    3. Amazon Echo Studio Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      댓글 쓰기
    1. Amazon Echo Studio Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Amazon Echo Studio Motherboard Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
      댓글 쓰기
    2. Amazon Echo Studio Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
      댓글 쓰기
    3. Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Amazon Echo Studio Motherboard Replacement: 10 단계, 이미지 3개 중 3개
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
      댓글 쓰기
    4. Amazon Echo Studio Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Colin Nicoll
회원 가입일: 10/26/22
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G6
4 회원들
안내서 13개를 작성함
6가이드 댓글
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - 답글 공유
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - 답글 공유
i also would like to know. mine stuck with cyan circle
Алексей - 답글 공유
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - 답글 공유
hi is there a place to buy this motherboard?
Bede Bede - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 64
전체 시간: 2,337
